Gap at bottom of steel security door
Gap at bottom of steel security screen door
I just installed a steel security door...the type which mounts to the outer existing wood frame. I noticed a rather large gap at the bottom. Any ideas on this one?
Hi, You installed a security door that mounts on the door casing or brick mold. The door extends beyond the threshhold of the original door and you have about a 2" gap at the bottom of the door. I have made a form to fit beyond the styles that hold the door up and high as the gap. place the form against the styles hold it in place with a brick or rock. Fill the gap with quick drying mortor. When set remove the form.
Good Luck Woodbutcher
