Reglazing old windows
Old 07-18-05, 07:42 AM
neunzy
Hello,
I am in the process of reglazing my wood windows and have a few concerns.
I am using a propane torch to remove the old glazing compound. Small areas of the glass panes have cracked in the corners, I imagine from the heat. Do I need to replace the whole pane of glass?
Also, after the old glazing has been removed, I have been wire brushing the area then using a shop vac for the bebris. Is this sufficient surface preparation?
Thanks in advance,
Aaron Neunz
Old 07-19-05, 03:34 PM
Lugnut's Avatar
Glass is cheap and easy to cut. Replace it sounds good to me. Wire brush down to wood is good for reglazing.
Old 07-26-05, 06:15 PM
zerokarasu's Avatar
why on earth are you using a propane torch? i used a hair dryer and it worked fine. plus you don't risk damaging the glass or wood.
