Mirror Door frame
Old 07-24-05, 09:56 PM
nkwok
Mirror Door frame
I have a mirror sliding door with 2 vertical sides of the frame came loose around the center. Part of the rubber strip around the center sides were retracted inside the frame. I would like to know if it can be repair like re-seat the rubber strip? And how do I glue the rubber strip to the frame sides and the mirror? Thanks!
Old 07-25-05, 12:48 PM
johnam's Avatar
Received 12 Upvotes on 11 Posts
Remove the doors.....remove the screw at each end and remove the frame. Apply a bit of clear silicone sealant inside the rubber strip and replace the rubber and then the frame.
Old 07-26-05, 07:32 PM
nkwok
Thanks John,
I did not see any screw around the frame. Are they hidden? Btw, the roller wheels are mounted on the top of the frame.
Thanks,
Norman
Old 07-27-05, 05:54 AM
johnam's Avatar
The frame had to be put around the mirror somehow. It is possible that the frame is a one piece construction that is actually bent at the corners and one corner has a tab the fits in a slot to hold it together. Look for that.
