Concrete block widow, door openings
Old 07-27-05, 05:35 PM
Mudball
We are building a concrete block house. Any particular reason we cant just have the windows and door sized to a replacement window rough opening size and then install window and attach straight to concrete block then caulk ?
Treated lumber is better than regular kiln dried but eventually will have to be replaced if not properly dried, treated and then wrapped.
It seems to be a good idea to install vinyl replacement windows directly to the block and then seal.
Thanks
Old 07-27-05, 05:44 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
If you can get a masonary nail or masonary screw to go through the nailing flange and into the edge of your cement rough opening without splitting the cement, then it's a great idea. Unfortunately, I don't think it's possible, which is why cement openings are lined with PT wood.
Old 07-28-05, 05:37 PM
Mudball
Thanks XSleeper.
Sounds like I'll be having PT installed.
Thanks
