working with a load bearing wall
Old 08-16-05, 08:15 AM
D
Not sure if this is the correct forum for this question. I plan on building a interior window (view thru?) from my kitchen into my dining room. Size will be approximately 50in. X 30 in. The wall I am going thru however is a load bearing wall. Do I have to do extensive bracing for this project or is it small enough that no extra support needs to be added. hope this is clear.
Thanks
Old 08-16-05, 10:22 AM
Received 1 Upvote on 1 Post
Since it is a loadbearing wall, you will have to have a header over the opening. This is the same thing as any other door or window opening. Interior or exterior makes no difference.
Dick
Old 08-16-05, 12:00 PM
D
Good. But is ther some guideline as to how big the header has to be - or will a 2X4 be adequate? I am thinking of doubling up the 2X4 for the header, and then doubling up the studs on either side. Does this make sense?
Thanks for the help.
Old 08-16-05, 12:55 PM
Hellrazor's Avatar
More like a double 2x10 or 2x12 header...
