cant find handles for thin door
Old 09-16-05, 06:55 PM
doorjam
hello all. i have an old exterior door that is about 1 1/16 inches wide. my problem is that all the schlage door handle sets are too wide for the door (standard 1 3/8 in.) Anyone know where i can special order such handles on the web or any other suggestions??
thanks
Old 09-16-05, 07:32 PM
L
Received 1 Upvote on 1 Post
Replace the door.
Trying to find a lockset that will fit it is going to take time. And, if you DO find the lockset, it'll cost at least as much as the new door will.
Old 09-19-05, 01:39 PM
doorjam
the situation is somewhat delicate tho. the door is painted the same to match house and its mostly glass...any more tips?
Old 09-20-05, 08:57 AM
T
Are you saying the door is not thick enough?
If so... check out the possibility of cutting down the main shaft of the lockset to allow a decent fit.
If not... get creative... decorative blocks typically used for trim/molding could be adapted to give you some depth to the door.
Necessity being the mother of invention......
