Installing Windows in Winter
Old 12-05-05, 09:14 AM
Haf
Is there any problems associated with installing windows in the dead of winter?
Old 12-05-05, 09:56 AM
XSleeper's Avatar
Received 1,747 Upvotes on 1,571 Posts
Yes. The installers get cold.
Other than that, there's no difference. It could be the quality of the work might go downhill as a result... I know that I sure do better work when I'm not freezing my fingers off. And as long as they aren't using latex caulking, there should be no other problems.
Old 12-05-05, 04:35 PM
O
Received 12 Upvotes on 9 Posts
cold?
LAUGHING!!!!
First line - Great reply!
Old 12-07-05, 09:53 AM
Haf
What about caulk - should we use a specific kind? Will it dry or cure?
Old 12-07-05, 04:41 PM
XSleeper's Avatar
Any kind but latex. That means you could use 100% silicone, or any of the petroleum distilate based types of caulking. Silicone will still extrude easily in cold temperatures, but you don't want to use silicone for your finish caulking- around siding or window trim. Silicone is not paintable, so that's where you'd want to use siding caulking that is the right color... such as OSI Quad or Geocel Pro Flex.
