Replacing a storm door?
Old 01-22-06, 04:58 AM
C
Question Replacing a storm door?
Hi,
I recently had my aluminum storm door damaged in a wind storm.It needs to be replaced.How hard is it to replace this myself?I've never done it,but have worked on houses quite a bit...Thanks.Any tips would be helpful.
Old 01-22-06, 05:36 AM
XSleeper's Avatar
Received 1,746 Upvotes on 1,570 Posts
It's pretty easy. All you need is a hacksaw, drill, drill bits, phillips bits, pliers, maybe a hammer. If you can follow instructions, you can put on a storm door. Storm door instruction manuals are almost always well illustrated and are very understandable. Should be a piece of cake since you will be replacing an existing storm door. It would probably take a beginner 2 hours start to finish.
Old 01-22-06, 10:26 AM
F
If you already had a storm door, then you're set. This means the wood for the mounting is already there and presumably the right dimenions. It's really an easy job and I just replaced mine about a month ago.
