Some Ideas please.
Old 01-28-06, 06:05 PM
B
Question Some Ideas please.
I have a room that I’d like to keep my cats out of, I was wondering if anyone knew of a door solution that would A.)Let the light still come in, B.)Let the air circulate, and C.)Keep the cats out. Any ideas would be greatly appreciated.
Old 01-28-06, 06:53 PM
L
Received 1 Upvote on 1 Post
Interior or exterior door?
Old 01-28-06, 07:05 PM
B
Interior. It's a doorway into a "formal" living room if that helps any.
Old 01-28-06, 07:19 PM
majakdragon's Avatar
Sounds kind of impossible unless you put in doors with glass pane sections. That would not allow the air flow though. Ever think of using the Invisible Fence system? Run the wire across the doorway and put the collars on the cats. May take a while but it IS a deterent. Good luck.
Old 01-29-06, 05:20 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I am sure the room is air conditioned/heated, so if you were to install full light french type doors, the bottom of the door raised up about an inch should give adequate return and ample light, and keep the cats at bay.
