many questions about standard window frame sizes- and glass panes- i am so confused
ok i have a house that i am doing several things to- in order to fix it back up so i can rent it out again, one of the things is to replace two existing wood frame windows- each in a bedroom next to each other,
the house was built in 82 and the windows were alread old used ones when they were installed- and also are two different sizes and brands and such
so i want to modify/match the rough openings to be the same- like they should be- and put in brand new standard size vinyl clad double pane double hung
new siding is going to go on the house, as it has none currently, and the gypsum board work that will need to be done will be no big deal for me either,
where i am stuck at is with standard rough frame sizing rules/standards
also the local zoning code calls for the bottom glass pane itself to be at least 34" wide- and at least 24" high- and for the total glass surface area to be at least 5.7 square feet
now how am i supposed to know exactly which new standard size window units will have the bottom glass pane be at least this big ?
and how does rough frame sizing work- in regards to standard replacemnt window units ?
i heard that the advertised size of the window units is the actual overall size of the unit ?
so then i would add the two inches to those to get my rough frame opening size ?
or ?
please explain, because i am way beyond lost on how all this works
this stuff is so complicated
or i am just over looking something ?
thanks i appreciate
fastr68@yahoo.com
or ?
thanks i appreciate
fastr68@yahoo.com
Originally Posted by fast68
and how does rough frame sizing work- in regards to standard replacemnt window units ? i heard that the advertised size of the window units is the actual overall size of the unit ?
hi, thanks, well it says egrees, but it also says net clear opening
doesnt that mean the glass pane opening itself?
no ? it sure looks like it on the zoning code paper i have form city hall zoning office,
or does it really mean the whole sash opening ??
maybe i should scan this windows size zoning page i was given by the city hall zoning dept and show you it,
im trying ot do what i can to get the smallest allowable windows in this house, as i am on a small budget and cant afford to be buying any more than i am allowed to install in the house, but it needs done
the only places i am going ot be able to shop for windows is at menards and lowes, as out here in cornfield no where IL there is nothing for anything, unless youre a farmer, i will have to travel a ways to get to these stores so i dont want to have to make a second trip, want to get it right the first time,
so maybe someone here knows of specific vinyl clad replacement double hung window units- at one of these two stores- that would be what i should look for ?
wen you say frame size- do you mean the window unit frame size, or the rough wall opening frame size ?
this is where i am stuck at,
what size is what ? what is the actual size of a window that is advertised as a such and such size ? do you add to that to get your rough frame size ? or?
help
thanks again
help
thanks again
here try this:
http://pic14.picturetrail.com/VOL515.../132124712.jpg
should take you to the window size zoning requirement page i just scanned and uploaded, hopefully,
thanks
thanks
Egress
That makes so much more sense! Window manufacturers list which of their windows meet those codes. Here's two examples:
Pella marks on their size chart which window "meets minimum clear opening of 24" height, 20" width, and 5.7 sq ft." They're available at Lowes and at Pella window outlets.
http://www.pella.com/resources/pdf/Plcdh-s.pdf
Andersen, available at Home Depot and Andersen window outlets, states the same thing at
http://www.andersenwindows.com/UE/Pr...BasicUnits.asp
Other window companies would have similar specs.
Check out those two sites for which windows meet the egress requirements. They also list frame sizes, and rough openings. Enjoy!
ok well thats good then
its hard to explain/describe sometimes, or often, especially in RE of things youre just learning about, such as this
so that window code paper i have really does mean the actual entire window pane opening size ? which is turn technically named the egress ?
ive been looking at the pella stuff but i cant see where it lists any rough frame opening sizes,
the anderson sizing illustration im having some trouble understanding how its laid out- how to interpret/use it, hmm
also does neither of the companies have just some normal vinyl clad double hung units anymore ?
what happened to the good ol vinyl clads that were common a few years ago ?
they must not make them anymore ?
im confused ?
i dont know what would be best for vinyl siding but i dont want any with wood in them, and i dont know anything about the aluminum clads, or maybe all windows have wood in them somewhere?
if there was a window dealer around here then i would just go and look and figure it out that way, but there are none out here, so hmm
the two windows i am looking to replace are 49"H x 33 1/2"W
and 56"H x 29 1/2"W
im looking to reduce them down to the smallest allowable size by code, the code in RE of the 5.7sq foot clear opening rule
i appreciate
Randy
im confused ?
and 56"H x 29 1/2"W
i appreciate
Randy
Answers
In both size charts, they put a symbol by the ones that meet egress codes.
and 56"H x 29 1/2"W
and 56"H x 29 1/2"W
It sounds like the two size charts mentioned will not be of much help if you're getting vinyl windows though. The size charts were for clad windows, not vinyl windows, from the 2 largest wood window manufacturers in the country. You need to consult the size guide of whatever brand you're getting. I think you really need to talk to someone who can walk you through this in person. Best of luck Randy!
I am working with architect drawings that have window sizes like "3050" on them. In one post here, I saw something that equated this to "3' wide and 5' tall". Is this for real, or was that post in error? If so, what does "3026" mean -- is it 2'6" tall, or 2.6 feet tall, or some other weirdness?
I see doors that are '3068' and I've got to assume they're over six feet -- surely 5'8" would not be legal... Yet when I look at Pella's data books, they show windows like "2525" which have a frame size of 2'1" x 2'1", in other words, 25 inches.
How do I know which one I'm dealing with where?
NYVillager,
This is one those times, it seems, you are right but you're second guessing yourself. On drawings, Yes 3050 means the window is 3' wide and 5' tall. And Yes, on drawings 3068 (pretty standard exterior door) is 3' wide and 6'-8" tall. Const. Docs. that call out a 5'-8" door wouldn't make it past the secretary at the plans examiners office!
anywho, pella uses a different convention. Yes 2525 means 25" wide by 25" tall. As for other window manufacturers, without looking into it, I would only assume that they follow the same convention. However, this is easily confirmed by comparing that number (2525) with the frame size (2'-1"x2'-1") as you mentioned previously.
