Replacing Interior door
We are getting ready to replace the interior doors in our house. We are not using pre-hung, just replacement doors. I was wondering if I could get some tips on how to cut in for the hinges, whats the best type of tool to use? Any advice will be greatly appreciated! Thanks!
Christine
Christine
On your new door decide what is the top of the door. Example on a six panel door the small panels go to the top. On a slab door the top may be marked if it isn’t then it will make no difference.
I have hung about 100 doors as a repair not construction. I will try to help you as best as I can.
With your old door in place check the fit. Most fits are OK. Fit is the reveal on the top bottom and sides of the door. With the old door still in place mark it top and back. The back is the side with the hinge pins. Mark the new door top and back this is for your reference it is very easy to get turned around doing this. Pull the pins on the old door and remove all the hardware including the hinge leafs. Do not remove hinge leafs on the door jamb. Measure the old door and cut the new one to that length be careful not to splinter the new door, score the door or clamp a piece of scrap wood on the side where the saw blade leaves the wood.
Set the old door on the side with the hinge mortise up. Line up the new door at the top of the old one. The back of one should be against the front of the other. With a combo square scribe the mortise of the old door to the new door. Now take one of the hinge leafs and trace the hinge between the mortise lines you just drew remember the pins on the hinge go to the back of the door. The hinge leaf is probably marked on the back side from paint or varnish, use this line to guide you when tracing the hinge. An interior door is 1 3/8”The hinge will set about 1 1/4” across the door. Use a router to cut out the mortise if you use a chisel be careful cut only across the grain of the door style or you will split it.
Install the leafs on the new door with only one screw on each leaf make sure to drill a pilot hole for the screw or you WILL SPLIT the door. If the door has 3 hinges , leave the middle one off until you fit the door.
Place the new door in the jamb put the top pin in first then the bottom pin, you may have to adjust the bottom leaf a little tap it up or down to make it fit. That’s why I use only one screw at first. With both pins installed, drill your pilot holes and put in the rest of screws in the top and bottom hinges.
Put a screw on the front of the door where the knob will go, you need the screw to pull the door closed so you can mark the door where it hits the jamb. Remove the strike plate off the door jamb. With a pencil mark the door where it hits the jamb. Remove the door and plane down to the line, take your time. You may have to mark the door 2 or 3 times to get the fit.
With a pencil, mark on the back side door casing, the center of the hole located on the door jamb used for the door lock Close the door and transfer the mark to the door. With a combo square use that mark to scribe a line on both sides of door about 3” long and across the style.
Now find the back set of the lock you are using. A new lock will tell you, if you use the old lock, measure the old door from the edge to the center of the hole. 2 3/8” and 2 3/4 are common sizes. Measure also the size of the hole you will need 2 1/8’’is common.
If the back set is 2 3/8. On the line you drew on the door make a mark 2 3/8 on each side of the door. If the hole is 2 1/8, use a 2 1/8 hole saw, cut half way through the door and finish the cut from the other side do not plunge straight through you will splinter the door. Mark the center of style and drill a hole to fit the door latch use a small as possible hole to fit the latch you don’t have much room to spare. Some latches need to be mortised to fit if this is the case put the latch in the hole and trace the face of it then remove the needed amount of wood and install it. Remember to drill pilot holes. Install the lockset and the third hinge if needed. Now wasn’t that easy?
Good Luck, Woodbutcher
If you use a router, you may find it helpful to make a jig to use with the router.
I did this job in my house last summer. I made a jig from a piece of 1/4" plywood and 4 strips of wood for guides on 4 sides.
Place 2 strips opposite each other and parallel. The distance between them is the diameter of your router base plus the length of the hinge. Place the other 2 strips at right angles to the first two.
With the router, cut out a hole in the plywood corresponding to the cut for the hinges. Experiment on the edge of a 2x4 to get your depth of cut equal to the hinge thickness. Place the jig on the edge of the door, lining up the marks with the edge of the hole in the jig. Secure to the door with 2 screws, or nail a 2x2 on the bottom edge of the jig and clamp to the door. Cut the mortise. This will cut a mortise with rounded corners. If you are using square hinges, finish out the corners with a sharp wood chisel.
I will send a photo of the jig as soon as I figure out how to do it.
I honestly wouldn't recommend slab doors for beginners. There are many variables. Even after doing this kind of work for over 2 decades I still groan a bit about having to hang slab doors. Not to be discouraging just you will want to be careful if you haven't done it before. As for morticing out the hinges. I like to use my porter cable cutout tool (thier version of a rotozip) with a 3/8" flush cutting bit. Nice and light with a small table for a light job like that, where a regular router would be a bit bulky. I take the hinge I am going to use and trace it on the door frame with a utility knife (pencil will get you too wide) then, after practicing on a piece of scrap to get the feel and check for proper depth, I hollow out all but about 1/4" all around the edges of my utility knife mark. The rest I chisel out with well, a chisel, and the utility knife. There are other ways but this has worked best for me. Good Luck!
