Louvred Closet Doors
Does anyone know where I can get reasonably priced louvred by-pass doors?? I have looked everywhere locally (Wisconsin)and can't seem to come up with any.
You can use any quality louvered paneled door as a bypass as long as you get the proper hardware for it. Now, the cheapo doors won't stand up to the punishment, so when I say quality, you may have to look for them through door sites on the web. I googled one, and their 36" units are only a mere $655 each, so it may not be what you are looking for. Now, you can't use "sets" of doors as bypass, as the hinges will hit and cause problems, but single panels should work fine. Check Stanley to see if you can find the bypass hardware, and I suggest the ones with the bottom track, all the way across the opening. They are a breeze to install.
