Shortening a metal-clad door?
Old 05-01-06, 07:24 AM
I need help shortening a metal-clad exterior door. I can cut the bottom off to the necessary length, but I fear that the edge will be ragged once I do. Any suggestions?
Stu
Old 05-01-06, 06:23 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Stu: Welcome to the forums. If it is your first or 100th, you will leave ragged edges, no matter how careful you are. The key is to make as clean a cut as possible, then with a file round off the offending edges toward the inside of the door. I have used metal cutting blades in my circular saw (preferred), and Rotary tools with metal cutting blades (requires two cuts, one on each side). Don't use a reciprocating or jig saw, however, or your jagged edge will look like one of your blades, and no amount of filing will help. Post back if we can help further.
Old 05-02-06, 04:12 AM
Wink
Oh, Darn! That means I'll have to buy a new blade (wink, wink!). Thanks for the suggestion - I'll give it a try. I'll also look for a sweep or some sort of gasket to seal the gap and possibly cover some edges.
Stu
