3 Panel Sliding Patio Door XXO format
Old 05-14-06, 12:36 PM
R
I am about to purchase a 3 panel Sliding Patio Door from American Craftsman at Home Depot. They say that I can set it up with an XXO (outside view) configuration. I'm concerned about that because the written order only shows an XOX configuration. My question is: Can the door be set up in the way that I want it, and is there anything I need to be aware of or concerned with before ordering?
Thanks in Advance for any Help,
RMA3L
Old 05-14-06, 01:26 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Normally the doors can be set for XXO, XOX, or OXX on site, but you should check with the supplier to make sure there are no hidden glitches that would prevent you from setting them up the way you want. The workorder probably shows the XOX as a default, but check it out.
