8-foot interior french door?
Old 05-17-06, 09:07 PM
Anyone have a source for an 8-foot french door suitable for interior installation? We have an exactly 96 x 80 opening between our living room and dining room and want to separate the rooms. We're looking for single pane oak doors.
Failing that, is it practical/possible to buy 2 4-foot doors and then custom build a meeting rail for them? The only places I've found to special order them are for exterior applications with aluminum or vinyl on one side.
Thanks for any ideas...
Old 05-18-06, 11:08 AM
Received 786 Upvotes on 689 Posts
Have you considered using the 4 -2' doors, making 2 doors staionary and just the middle 2 hinged?
Old 05-18-06, 11:58 AM
B
humm.. I see 2 options. You could have the door custom made to fit your existing opening (expensive) or you could frame down your header to make a standard 81 1/2" rough height. Easiest would be simply frame the opening to fit a nice prehung. If you are personally attempting to hang double slab doors and you are not experienced in it. I urge caution. It can be and is a fairly advanced project.
Old 05-18-06, 02:02 PM
Pro, the 96" dimension is the width -- I need a door that's standard height, but 8' wide. Not a problem with sliders, but seems to be custom in french doors.
Marksr, I was kind of kicking around the idea of just throwing a 6 foot unit in and 12" sidelites on the sides. Might be the best overall, since those 4-ft door panels would need a bunch of clearance to swing open.
This project will be me and my buddy who owns a home improvement company; he's been installing windows, doors, and siding for about 15 years. I know when to say when.
Old 05-18-06, 02:16 PM
B
oh my mistake just that 96" is 8' so threw me off. I have seen doors that tall in upscale homes with 10' - 12" ceilings. In that case I like the sidelights idea. sounds like you have good help. good luck
Old 05-18-06, 06:07 PM
Sounds like a plan
