door knobs that "stick"
Old 05-21-06, 12:29 PM
E
Hi,
I need help with a door knob problem. I changed a mortise lock and the door knob is now very difficult to turn. It was turning when I "dry fitted" everything. Now, it is incredibly difficult to turn. Any possible suggestions?
Thanks, in advance,
Ed
Old 05-21-06, 05:37 PM
Received 753 Upvotes on 658 Posts
Welcome to the forums Ed
You probably tightned the screws too tight.
Old 05-21-06, 07:46 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
If it is a mortise type, you may have the knobs turned too tightly against the plates. Back off one quarter turn so the set screw sets on the flat of the next turn.
Old 05-31-06, 07:48 PM
GlobalLocky's Avatar
9/10 jobs I have been called to a s a locksmith for this problem stem from either weathering or incorrect fitting.
there is a simple quick fix you can try but you may need to repeat it again every so often.
Use a a block of wood underneath the rosette of the handle and hit it up (or down - as the case may be) with a hammer.
Should rectify the problem...at least temporarily....or try the other methods for a more permanent solution
