fla room replacing jalousie windows with vinyl sliders? help!!!!
hi i'm a newbee, i have a fla room and it has old metal jalousie windows thay are huge anyway i have 4 in a row and i believe they are all connected. what i wish to do is replace them with 48x48 sliders by pella obviously they will not fit right in. what do i need to do. i'm very handy with wood and wish to do it myself. help ,i can get demensions if needed thanks anthony303
Welcome to the forums. Basically you will need to frame up the openings to accept the new windows. Of course this will entail interior finishing as well as exterior treatment, and insulation. Determine where you want the bottom of the windows to land, build knee walls. Are the windows you have in mind new construction with nailing flanges, or replacement type windows? It would be best to create a rough opening 2 inches wider than the overall window width, and 2 inches higher than the height. Then case the RO with 1x lumber to allow for external and interior trim molding attachment if required.
Good luck and post back if we can help further.
