Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
regular masking tape & stuco on plastic window frames
Old 07-08-06, 11:32 AM
A
Made the mistake of using regular masking tape (not painters) to mask exterior side of plastic window frames for stuco and then left tape on too long. What is the best method to remove this tape. Thanks in advance for your tips.
Old 07-08-06, 12:47 PM
johnam's Avatar
Received 12 Upvotes on 11 Posts
You will probably get many responses. I use benzine (naptha) since it won't harm the vinyl window frame. Spray it on or apply it with a cloth, let it sit for a minute then try to peel it off. If some of it still won't come off give it a second application.
Old 07-08-06, 04:21 PM
Received 753 Upvotes on 658 Posts
Paint thinner should remove the adhesive, unfortunatetly it usually requires a fair amount of elbow grease
Old 07-08-06, 04:23 PM
T
Received 1 Upvote on 1 Post
In addition to a solvent cleaner, a razor blade scraper may come in handy.
