Replacing a replacement Window
Old 07-25-06, 08:40 AM
Morning all,
I am needing to replace several replacement windows that have gone bad. My problems are as follows..
1) I have Steel Siding on the house
2) Never done it before..
3) All of the replacement windows I have seen have a white "skirt" around the outside which leads me to believe that the window would need to be installed form the outside???
Anyone have insight??
Old 07-25-06, 10:20 AM
W
Received 60 Upvotes on 52 Posts
Replacement windows
You may be confusing new construction windows with replacement windows. New construction windows have a nailing flange and are installed before the siding is installed.
Old 07-25-06, 10:34 AM
Good to know
Ok, now that I understand the difference between New Construction windows and replacement windows, I can look for the correct type, Thanks.
