~MobileHome Awnings~
Hello to All Who Read This & I Thank You in Advance for Your Expertise!! I Purchased a MH & There Are 3 Awnings That Are Not Attached to the House..Maybe From Last Hurricane...I Wanted to Know If It Would be Costly to RE~Attach them to the Home .I Dont Have Lots of $$ to Work With So Please Advise Me on Who I Should Contact for LE$$ Thanx ~Roze
Last edited by twelvepole; 09-01-06 at 11:33 PM. Reason: Deleted excessive written commands because distracting and codes turned off
I don't know too much about awnings. They are probably just screwed into the framing behind the MH skin. If the screw holes are ripped open you might still be able to use them either by attaching at a different spot or using a large washer to close the opening.
A local handy man would probably be the cheapest help to hire.
