adjusting sticky doors
Old 08-14-06, 11:13 AM
L
this summer, either from the heat or from my home shifting, 2 of my interior doors are rubbing against the door frames (sticky).
to correct this, do i sand down the top of the door or is there a better way?
thank you.
Old 08-14-06, 04:49 PM
XSleeper's Avatar
Received 1,745 Upvotes on 1,569 Posts
One trick you could try is to remove one screw from each of your hinges (one of the screws closest to the door stop- the trim that the door closes against) and replace the short screws with a long 2 1/2" or 3" screw that will go into the framing. What this will often do is pull the jamb a little bit tighter to the framing and widen your opening just a tad. It's often all that is needed to make a door stop sticking.
