patio Door seal
Old 08-31-06, 06:07 PM
daswede's Avatar
patio Door seal
I think my sliding double pane patio door has lost the gas seal between the two sashes. Is it posible to recharge,and can it be done in place?
Thanks
Old 08-31-06, 06:31 PM
Received 1 Upvote on 1 Post
patio Door seal
If your patio door glass is fogged the only thing to do is have the panel replaced. I had one done for $245 and it was done in 15 minutes including removing the door, cleaning tracks and adjusting the door.
If you can put up with the appearance, you can let it go. (I have one window fogged and have no plans to ever fix it because I never look out of it). The extra amount of energy lost through the window is so small, you cannot justify replacing the panel unless you plan to be there for for a long, long time - you lose more around the door than you lose through the glass if you have curtains or blinds.
Dick
Old 08-31-06, 07:11 PM
daswede's Avatar
Thats pretty expensive. I'll really have to think hard about
doing it. thanks
Old 09-03-06, 04:09 PM
L
If the seal has failed, the only option is to replace the IG (glass) unit. There is simply no way that you are going to repair it yourself. Call a glass shop. Sliders are standard sizes, and $250 or so isn't that bad. The other option would be to replace the ENTIRE slider -- now you're looking at $1K!!!
Old 09-03-06, 04:21 PM
daswede's Avatar
Thanks. Looks like the Glass shop is the way to go.
