replacement windows - no visible frames.
Replacing a couple of windows in our home. Current windows have wide wooden frames around them. I have seen photos of windows (I think Pella) installed so they appear to be flush at the edge with the wallboard - no visible frames. Any suggestions on how we can get that effect. Any recommendations on particular windows that would work with that type of installation. Rough opening is approx 78"
it sounds like you are talking about having a drywall return to the window instead of the usual wood casing and extension jamb. If so, that doesn't usually have as much to do with the window itself as it does the way it is finished (trimmed).
I think X has the answer. Drywall returns instead of trimmed woodwork is less expensive, and often seen in lower priced tract houses. No trim carpenter is needed, and there is no extra trim painting needed.
Sounds right, so I should talk to the drywaller not the window installer?? Anyone know if the brand of window would make a difference in this type of arrangement?
thanks
Pat
thanks
Pat
It depends on your wall thickness, but generally, if you are removing the entire old window (frame and all) and are installing a vinyl window with a nailing flange, the vinyl window will be mounted far enough toward the exterior that it will allow you to have a sizable drywall return.
Depending on your wall thickness, you might be able to use other types of windows that have standard 4 9/16" jambs and still have a drywall return. (For example, if your wall thickness is 6 9/16.)
Drywall returns at the sill
One other thought - If you have a drywall return at the sill, over time it can crumble and deteriorate from placing objects on it since drywall is easy to chip and dent. Therefore one will often see a drywall return on the sides and top of a window, but a wood or marble or laminate stool (sometimes called the sill) on the interior bottom instead of drywall.
After looking at some illustrations I am not sure this (drywall return) is exactly what I am looking for. I don't really want the window to be recessed much into the wall.
I am more looking for a way to eliminate the interior window casing (I think that is the correct term - the visible wood "frame" added around the edge of the installed window) and instead put the drywall up to the edge of the window frame. (wish I had a good photo to attach).
Pat
Pat
