New tile won't fit under pocket door...
We're going to install tile in our bathroom. With 1/4" hardibacker plus the tile, the floor will be taller than the current clearance of our pocket door. I was thinking about stopping the tile short of the door, but then there will be a small step that I'd rather avoid. Ideally, I'd like to shorten the door and then install a threshold between the tile and the bedroom carpet.
Maybe I'm crazy, but the last thing that I want to do is remove the pocket door. Is there any kind of tool that can cleanly cut a 1/2" off of the bottom of the door while it's fully extended (i.e., closed)?
I'm thinking that I could make a rough cut from either side with a sawsall and then tediously sand it from the bottom up (luckily it's only 30" wide), but I'm hoping there's a better way ... or, again, maybe I'm just nuts.
Any ideas?
Any ideas?
There are ways to cut the door in place, but it is not easy and often impossible to keep a straight line. But taking the door out is not that hard, you do have to remove some of the trim, but nothing else.
Well, I should have thought this through earlier. For the tile to be flush with the door jamb, I need to remove the trim anyway. So, it only makes sense remove the door.
It was a pain, but now I have a nice clean line, and it was much easier to paint!
