French Door Repair
Old 02-06-07, 11:39 AM
F
French Door Repair
Does anyone know where I might be able to purchase repair parts for a french door, the bottom latching pin that fastens in threshold plate on my door is broken, it's the steel pin incased in plastic that slides up & down to secure the door. Thanks !!
Old 02-06-07, 04:00 PM
Is it internal to the door, or an add on screwed to the door face??? if an add on, any well stocked hardware or home store should have something that will work. If part of the door, contact the manufacturer if you can find a name. Otherwise, plan A above.
Old 02-06-07, 04:01 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! Do you know the brand name of the door? Can you access the rod mechanism from the outside?
Old 02-06-07, 06:30 PM
F
French door locking pin
I'm sorry I don't know who manufactured this door, but the device is asessible, it's located in an open channel in the edge of the door..Thanks!
