Using a standard prehung split jam door
Old 03-29-07, 05:30 PM
E
A standard split jam is 4-9/16 inches. Will this jam expand out to 5-1/4 inches so I can use it with my plaster/2x4 wall? Special order 5-1/4 jam prehung doors are costly. Thanks in advance.
Old 03-30-07, 04:02 AM
It is easy to add extensions to door jambs. Just make the pieces in the width you need and nail/glue them to the jamb. Careful alignment on the exposed side is important, does not matter on the hidden side.
