replace all windows?
Old 04-02-07, 08:07 AM
R
I plan on replacing all the windows in my house except 3 bedrooms that have magnetic windows installed on the inside. Should I consider replacing them as well with the double paned vinyl to get maximum energy efficiency? Will it make that much of a difference? I ask because the cost will be significantly more because each bedroom has 2 windows. Thanks for any input.
Old 04-02-07, 02:33 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Not sure what the magnetic windows, except to be a substitute for storm windows, trying to add an insulation factor. You don't want to use them with insulated glass, so you can breathe easier on that issue. Are you replacing the entire window units or are you installing replacements inside your existing framing?
