Storm door Window
Hello Helpfull Folks..could someone Please tell me if I can take apart the Storm window to replace the spring loaded slide latch? It looks like it has the corner pieces..so, do thiese coume out with out much problem, or what is the best way to do this without taking it to a window shop??
Make sure that you can get the slide latch before you start. There are hundreds of different ones. The corner pieces do come out in different ways. Some are staked (you'll see dimples in the frame holding the corner in place), others have tiny screws on top or side, others lock in place by friction and probably 2 or 3 other ways. It might be worth bringing it to a glass shop for repair.
