How to obscure a window in the shower
Old 05-09-07, 11:50 AM
I have a window in the shower/tub that used to be frosted. The frosting is wearing down and now the window is essentially see-through like any other. So, if you're in our backyard, one can see in the shower clear as day. Makes for an awkward scene if you're the one taking a shower. Anyway, I'd like to replace the window eventually, but for now am looking for a temporary fix. Is there a way to refrost the window? I also heard something about applying an acid base to the window to create a texture that would make it difficult to see into. I obviously need something that can withstand direct water and moisture (both from the shower and from outside). Any ideas or suggestions would be much appreciated!
Old 05-09-07, 12:00 PM
core's Avatar
How temporary? How quick? Do asthetics matter? If just for a few days while you're looking for a pretty replacement or re-frosting you could just get a can of that fake frost that people use on their windows at Christmas time.
Or... I could swear they used to sell blow-drier-shrink window plastic that was cloudy colored. But all I've seen recently is the clear stuff.
I'm assuming you've already decided against a permanent window covering which would still allow light to pass such as fabric blinds, thin drapes, etc.
Old 05-09-07, 12:07 PM
Well, I guess I'm thinking more permanent than a few days. Probably more like a few months.
I can't use blinds or drapes because the window is literally IN the shower and gets wet. For that reason, the frost spray used at Christmas time also won't work. When I moved in 3 years ago, it looks like it was actually a permanent frosted glass, but obviously that isn't the case as the frosting is almost completely worn away. I could try to do the same thing, but don't know where to get something like that.
Old 05-09-07, 12:13 PM
core's Avatar
How about this spray?
http://www.amazon.com/1903-FROSTED-GLASS-FINISH-per/dp/B0009XCKBA
Says it can be used on shower doors, so I'd assume it would ok for your use? Also if you happen to make a mistake and get it on something try hydrogen peroxide. Never used this stuff myself but the peroxide works for similar sprays.
Old 05-09-07, 01:41 PM
Frosted clear contact paper is an option.Sticks on,can't been seen through.cut to fit.Only possible issue would be removal at a later point.
Old 05-10-07, 01:48 PM
Thanks! I'll look into both of those options. Do you know where I might get the frosted paper? I asked at Loews and they had no idea what I was talking about, but haven't tried Home Depot or other hardware stores yet.
Old 05-10-07, 02:34 PM
If you have an Ace hardware near you they will stock it or at least be able to order it for you.It is part of most of the Ace houseware dept. planograms.
Old 05-10-07, 04:30 PM
T
Received 1 Upvote on 1 Post
According to the Lowe's website, they have the cling privacy window film. They describe as follows: "Frosted privacy films are translucent and allow light to pass through while providing 24-hour privacy. Mirrored privacy films provide daytime privacy. They allow you to see outside, but stop others from seeing in during the day."
Old 05-10-07, 05:33 PM
Or you could do business where they know what you're talking about and that they actually do sell the item.
Doesn't matter if they carry something if they don't know they carry it.
Old 05-10-07, 05:38 PM
You're right about that. It was a bit of a frustrating conversation w/the Loew's guy, but I could have been just talking to the wrong person. I think also knowing the exact product name helps and I thank you all for your feedback on that. I look forward to showering "alone" soon - and I'm sure the construction workers behind my house will be grateful too!
Old 05-10-07, 07:47 PM
the_tow_guy's Avatar
Received 198 Upvotes on 158 Posts
You definitely spoke to the wrong guy. Lowe's and HD both carry window films that will do the job. I used one of them to spruce up the sidelights by our front door and the fan-shaped window over it.
http://www.lowes.com/lowes/lkn?action=productList&Ntt=window%20film&Ntk=i_products&category=Yes&N=0+4294967016
http://www.homedepot.com/prel80/HDUS/EN_US/diy_main/pg_diy.jsp?CNTTYPE=PROD_META&CNTKEY=misc%2fsearchResults.jsp&BV_SessionID=@@@@2140438683.1178851701@@@@&BV_EngineID=ccceaddklklijfmcgelceffdfgidgjj.0&MID=9876
