What is the difference???
Old 05-09-07, 01:55 PM
H
Question What is the difference???
Hello,
Can someone tell me the difference between insert windows and a full frame replacement window? We have a 1950's ranch style home with the original windows, needless to say they all need to be replaced. But what is the difference between an insert window and a full frame replacement? I understand that an insert is just popping one window into the same hole from the old window. Another question I have is, would doing that negate the whole reason you get new windows? We want new windows but what if the frame is bad, just putting a new window in a bad frame does not sound like it is too good of an idea? Any info would be helpful, I am ignorant when it comes to windows.
Thanks!
Old 05-09-07, 03:24 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You know the difference according to your post. You are exactly right in that the replacement windows slip into your existing cased opening and are fastened and molded accordingly. If your molding is in good shape that is the way to go. So often, however, the casing is rotted, the sill has definitely gone south, and brick or exterior molding at the bottom is wasted.
In that instance replacing the entire window is the only option, unless you are good at rebuilding cased openings. Exact measurements are critical. I just finished replacing 12 in a house here, locally, and I was very fortunate the owner had the window measured, ordered, delivered and on site for me to put in. They were a breeze.
Installing them will be definitely a DIY project. BUT I would have a pro from the window company come out and measure so you can be assured of a good fit.
Let us know if we can help further.
Old 05-10-07, 07:51 AM
H
Thanks Chandler!
The sill (area at the bottom of the window) is actually in pretty good shape, does that mean the frame is okay? The windows are actually in good shape considering they are 50 years old, but none of them open (which scares me). The windows have never leaked or had condensation or anything on them, if only they would open we would be okay with keeping them. If we go with the replacement windows, how hard are they to install? Thank you for the help!
Old 05-10-07, 08:50 AM
T
Just replaced 10 windows in an 85 yr old home. Bought double pane replacements for a couple hundred apiece (average). Removing the old window is easy and replacing with the new is easy also. If your existing framework isn't rotted out - then you're probably good to go. With moderate DIY skills - a couple of simple tools - and accurate measurements (measure carefully, making note of exactly what you're measuring - and explain it to the salesman) - replacing those windows will take about an hour or so apiece... and will look/function great!
If you're not sure of your abilities - get a pro to give you an estimate - it will be spendy, for sure - but it beats buying a bunch of windows that won't fit - and you can't return.
