Argon vs Krypton gas in replacement windows
Old 05-22-07, 05:12 PM
B
Am buying replacement windows for front of house. All others in house are now double pane. I am now looking at triple panes for front windows. Should I go the extra 10% for Krypton vs Argon gas? Or am I tossing good money away for little or no extra return?
Old 05-22-07, 07:27 PM
XSleeper's Avatar
Received 1,720 Upvotes on 1,544 Posts
I'm not quite sure what you are asking. If gas fill is used in a triple pane unit, it will always be Krypton. If gas fill is used in double pane units, it is almost always Argon.
One is not necessarily better than the other, it is simply a matter of physics. Argon performs best inside a dead air space that is roughly 1/2" wide, whereas Krypton performs better than Argon in smaller spaces- roughly 1/4" wide or so.
The gas fill will obviously increase the u-factor of the windows. It's hard to say whether it is worth it. Kind of like asking if heated seats are worth it in a new car. Probably depends how long you will be in the house.
Triple pane/Krypton units are quite superior to Double pane/Argon ones. You didn't mention Low-E, but hopefully that's included in the mix as well.
To help you rationalize whether it is worth the extra money for the better glass package, consider this illustration (example): You have 4 walls of a home. 3 of the walls are filled with R-13 insulation, while the 4th wall is filled with R-19 insulation. The 4th wall certainly will feel warmer than the others and will be more energy efficient. R-19 costs more than R-13. Is it worth it? You'd have to run the numbers if you want to know how many years it will take for payback. The same might be said for your windows. But it's hard to calculate because when it comes to windows, so many other factors are involved. Unless your old windows were*very* drafty or were single pane, new efficient windows actually will take a very long time to pay for themselves.
Old 05-23-07, 04:37 AM
Sleeper pretty well covered it, but to add, gas filled(regardless of which) makes the windows more energy efficient at only a small price increase, definitely worth it with todays energy costs. Double pane vs tripple pane is different, likely a big cost difference and hard to justify. If you were to stay in the house for a long time, I might consider it.
Old 05-26-07, 06:44 AM
O
Received 12 Upvotes on 9 Posts
gas
What they said ^...
To follow-up Just Bill, energy costs are going to be going thru the roof - there is no end in sight.
And to follow up X-Sleeper a bit - the advantage of the triple pane is the LowE coating. Triple pane allows the manufacturer to coat two different lites - generally surfaces 2 and 5 - and that is where the real advantage of the triple pane lies.
Again to follow up on X-Sleeper's comments - and as a general guideline - some triple pane windows are made with wide (~7/16" or so) air-space between the lites. In that case go with argon because the krypton upgrade would not be worth the extra cost.
But, if the windows that you are looking at have ~1/4 airspace then by-all-means go with the krypton because then the upgrade is probably worth the extra money.
My daughter is currently building a home. The windows that I spec'd for her home are triple pane with dual LowE coating, wider airspace, and argon fill. The fixed units have a rating of U -.16 and the operators have a rating of U -.21. Again, with argon and wider airspace. These were not frighteningly expensive windows.
It is possible with current technology to get down to about a U -.1 with narrow airspace and krypton fill - but it can get very expensive to do so.
Old 09-09-10, 04:56 PM
E
argon vs krypton
Krypton is going to be more expensive because it is harder to get out of the atmosphere. It is also 10 times more dense than argon. If you could fill a swimming pool with argon it would be like swimming in water. If you could fill a pool with krypton it would be like swimming in jell-o. Argon will eventually leak out of your windows. Krypton will stay for 50 years or more. Is it really worth the extra cost? I bought a sliding glass door from Thermal King last year and this door faces west. Plenty of light comes in but no heat. I mean you can put your hand on the glass and feel a slight warmth. This is in 100 degree plus heat. If you can afford the triple pane with krypton you won't have to worry about anything for 50 years. If not go with the double pane argon filled. I undersnd Champion windows are the best at this.
Old 09-09-10, 05:39 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Ewking53, welcome to the forums! The information you are conveying may fall on deaf ears as the posts were over 3 years old. No problem. Keep good info comin'.
Old 09-09-10, 08:26 PM
XSleeper's Avatar
ROFL! That *is* good information! Except for the part about Champion. And the part about Krypton taking that much longer to leak out v.s. argon. And from what I can find, it is 3x more dense than Argon. If you filled a swimming pool with either argon or krypton you would suffocate! All in good fun!
I do prefer triple pane w/krypton though.
Old 09-10-10, 03:26 AM
chandler's Avatar
And you know what happens to leaking Krypton......just ask Superman.
Old 09-10-10, 05:22 PM
E
argon/krypton gas
xsleeper, the gas is so much heavier than air, as long as you kept your head above the gas you would be fine. You are correct about the density 3 times is right. I will still keep my 50 year warranty with my door though. Argon is the same density as water so it will leak out, leaving you a dead air space in your windows. Don't know if this is really bad though.
Old 12-18-10, 07:26 PM
B
Krypton filled replacement windows
Does anyone know who produces double or triple pane windows, filled with Krypton? I am interested in fiberglass framed windows, the majority will be picture windows with a few casements.
Old 12-18-10, 07:47 PM
XSleeper's Avatar
beaky,
welcome to the forums. When asking a new question it's usually best to start a new post, rather than hijack someone else's question or resurrect an old thread.
In answer to your question, any company that makes windows will offer glass options, including double pane with argon or triple pane with krypton.
