door trim
door trim
we have installed an exterior door stained a different color than the two closet doors on either side of the door. should we stain the trim to match the trim around the closet doors or should it match the exterior door?
Since decorating is a personal choice, the correct answer is whatever looks best to you. But you will likely find that the trim and door are different woods and will not be the same color with the same stain. Which is why you often see trim painted and doors stained, or vice-versa.
