Window 'Friction Hinges'
What are "friction hinges" used for?
Can they be used not only with casement's
but also with push out awning windows?
thanks!
thanks!
Friction hinges have a variety of applications. They should work for your project. The main consideration is the weight load - you'll need to buy hinges heavy enough to hold the awning where you want it.
