Dual Pane Replacement Glass - French Doors
Old 06-29-07, 05:56 PM
Post Dual Pane Replacement Glass - French Doors
I have single pane 10 lite French Doors and want to replace the single pane glass with dual pane (glass only), but can not locate a seller for the dual pane glass (ONLY). Can anyone help. I have a Delta shaper and the "exterior door" making set and intend on building two more French Doors and want to put dual pane glass in them as well as replace the glass in two 10 lite side panels and two existing French Doors.
Old 06-29-07, 06:31 PM
johnam's Avatar
Received 12 Upvotes on 11 Posts
Most local glass shops should be able to order the glass. Go to the yellow pages under "Glass, Plate and Window".
