vinyl window glass replaced
Old 06-29-07, 09:41 PM
T
Hello all,
I have vinyl windows in bathroom that about 2 years old. We are completely redoing the bath now and would like to have frosted glass, not clear like we currently have. Is it possible to switch out the window panes, without replacing the entire window?
Thanks
Jamie
Philly
Old 06-29-07, 09:54 PM
XSleeper's Avatar
Received 1,749 Upvotes on 1,573 Posts
yes, any glass house could fix you up.
Old 06-30-07, 03:58 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Of course you could apply a frosted tinting on the windows and save the cost of the window pane replacement.
Old 07-04-07, 04:37 PM
T
Thanks for the replies. I will check the cost of the replacement of glass. If its too too high, we will just frost the lass with a spray. I assume the contact paper frosting wouldn't be a good idea since it is a bathroom. Is this correct?
Jamie
Old 07-05-07, 04:11 AM
chandler's Avatar
Actually the self adhesive window frosting is meant primarily for bathrooms, so it should be good for your application.
