Entry door replacement question.
I have two original wood entry doors. They are not very efficient in the winter and one of them is warped. I have older gelassi(sp) screen doors on both of the doors I would like to keep.
Can I replace the entry doors only and leave the screen doors alone? Or would they both have to be replaced?
Thanks.
Thanks.
Those storms are not much more efficient than the doors you want to replace. But the new doors will be, if you use a prehung door set. If they are a standard size, they can be reused. Even if slightly smaller they will work, with some shimming. They may not look good next to a new door.
