Andersen 3 panel double glazed center fixed panel replacement
Does anyone have information as to wether the center fixed panel (2 outer panels swing open)on a 3 panel Andersen double glazed window can be replaced. This window is installed on a 20 yr old VT home and has discolored?
Total window is approximate 4-1/2' X 4-1/2' divided into 3 panels. Any help will be greatly appreciated
The center panel on your window is held in place by metal tabs that have been stapled to the window frame. There are probably at least 2 or 3 tabs per side. You can expose these metal tabs by removing the interior stops that are around the perimeter of the window. For ordering or warranty information, you'll need the code that is etched in the bottom corner of the glass. The site Johnam mentioned should give details on that.
