wall around alumin windows
Old 10-12-07, 07:14 AM
Unhappy wall around alumin windows
I have taken off bubbling paper and paper from inside of window. There are two or three crackes that have let in moisture that has turned wall black. I cleaned and sanded the edges but what do I use to seal the cracked in the wall. One of the crackes is on the right side of the window and the other is under it. Not sure what steps to take to insure no more leaking???? This window was put in real rought I mean sloppy job. There is a space of 1/4 from the frame to the ledge of the window frame. This is all inside of the house.
Can anyone help. it shouldn't be to difficult of a job but I'm unsure of what is next.
thank u
mugsy1349
Last edited by mugsy1349; 10-12-07 at 07:18 AM. Reason: need to add the word "cracked" to that sentence
Old 10-12-07, 05:01 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
It sure would help us to help you if you could post a couple of pictures of your problem on a site such as photobucket.com and give us the urls.
