Screen Door for Sliding Glass Patio Door
Where can I get a screen door for my sliding glass patio door?
The size from stucco to stucco is 95 1/5 inches high and 59 1/4 wide.
Does that sound right?
Unless you know the manufacturer of the door, you'll have to get one made to order from a local glass shop or window & door dealer. They will tell you where to measure.
Screen doors can be a real pain in the butt! Take a look at these from Amazon. I hate my screen door and am replacing it with one of these split screen ones.
http://www.amazon.com/s/ref=sr_nr_se...r%2Ci%3Agarden
Forget about any screen door that's not heavy duty and made to order. Do not buy one that's adjustable, they never work properly.
dn0121,
Thanks for the reply, but that is not what I am looking for.
johnam,
I did find a sticker on the very top track.
J-180-1
Spec SGD-C30
MST 12080
If that helps at all
johnam,
J-180-1
Spec SGD-C30
MST 12080
JRockFL,
Go see a local glass shop! There is more to a screen door than just the size.
How is it pocketed? What rollers are involved? Is it rollered only on the bottom, or are there rollers top and bottom? What is the thickness of the frame? ... And the questions go on an on, and on, ...
