Installing pet/cat door
Old 11-05-07, 05:46 PM
D
OK, I have a nagging wife and kids who want a cat. The only place to actually put a litter box would be our laundry room that is entered through the basement/family room. I can not leave the door open at all times and need the litter box accessible of course. Installing a cat/pet door would not be hard, but I am wondering if anyone knows if this can be done in a pre-molded 6 panel door. This is the cheap $30 doors you get from HD or Lowes. I am not even sure what exact material it is made from. I looked all over google and other places but can find nothing. Almost all pet doors lead to outside and these doors are not used for that purpose. Anyone able to help?
Old 11-05-07, 08:08 PM
Larryu's Avatar
I did one of those recently at my daughter's house.The door appears to be made out of a thick cardboard but the cat door went in with no problem.
Old 11-06-07, 02:46 AM
D
I guess I can just go for it. The worst thing I guess that could happen would be buying a new door for $30.
Old 11-06-07, 04:54 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
A 6 panel masonite door may not give you the proper height-to-center-of-panel relationship. Cats can jump, but they won't jump and push a door at the same time. Installing the door is pretty straight forward. They send you a template with the door, and if you drill straight, level pilot holes through the door and cut it with a fine blade jig saw, it installs like a clamshell. Look at the height and see if it is viable before you drill.
Old 11-06-07, 09:44 AM
C
I installed a cat door in a 6 panel masonite door with no probs. It is right in the middle, in between 2 of the panels. It isn't flush all the way around, but it looks fine.
