doorknobs I bought don't fit...help!
Old 12-02-07, 10:00 AM
C
I tried replacing the doorknobs on my interior doors--I'm guessing they haven't been replaced since the 70s.
The problem is the holes on my existing doors are only 1 5/8" diameter instead of 2 1/8"--which most new interior doorknobs seem to require. I tried to cut the old hole to 2 1/8" but ended up chewing up the wood on the door. So does anyone have any suggestions?
FYI - the backset on this door is 2 3/8".
Old 12-02-07, 10:52 AM
XSleeper's Avatar
Received 1,743 Upvotes on 1,567 Posts
Take a piece of wood (like a 1x4) and clamp it to the door, covering up your current hole. Then using a hole saw and mandrel, drill your new hole through that piece of wood. It will act like a guide to keep the hole saw drilling straight through the door. All you have to do is make sure you center the pilot hole on your 2 3/8 backset and hit the center of the bore for the plunger.
Old 12-02-07, 10:56 AM
C
thanks for the advice....i imagine it would be tricky to get the hole centered...but much better than chewing up another door.
Great advice....
Chesapeake.
