Threshold
Old 12-08-07, 07:44 PM
P
Threshold
I need to put down a threshold from carpet to hardwood which both are on a concrete slab. The space in between the carpet and hardwood is about 1/4 inch. The threshold I have has the holes in the middle for the nails to go and of course it hits in the space where the slab is. How do I put this down on the slab? The nails just bend and don't go in the slab.
Thanks
Sade
Old 12-08-07, 09:47 PM
2
Install plastic shields first. The plastic shields are intended for use with small screws in drywall but they work well. Look for small “blue” ones. They are about 1/8” diameter.
Using the threshold mark the hole location. Using an 1/8” masonry bit bore holes for the anchors. Hammer the anchors in. The proper anchors will fit tightly in the hole. Install the threshold as usual.
Old 12-09-07, 05:19 AM
Use masonary nails or tapcon screws. Screws require predrilling, but usually causes less damage and hold better. Of course there are powder actuated nailers, but that is usually overkill for a carpet strip.
