broken sliding glass door latch
Our sliding glass door latch is broken. If you lift the latch to unlock the door, it doesn't unlock. We can't get the door opened. Any ideas on how to fix it?
Thanks,
Matt
Thanks,
Matt
Tough one, is there a brand name on the door?? You may be able to remove the part that goes thru the door and unlatch the mechanism from the hole in the door. Then you can figure what is broken. Forcing it will only break more things. If in doubt, call someone that knows.
