Door Wood Rot Help
Door Wood Rot Help
The back door is rotted at the bottom on both sides and the sill. I will obviously replace the sill, but any ideas how to cheaply fix the door frame bottom without replacing the door frame?
Thanks
Thanks
Hi jzeebas1,
Welcome to DoItYourself.com and the door & Window forum.
Depends on exactly what the door is.
I'm imaging that you are talking about a rail and stile wood door with some panels and possible a glass pane in it.
If that's the case, you'll need a small arsenal to tools (router, table saw, clamps to start with) to duplicate the parts that need replacing, and a free weekend or two. And you'll need a source for top grade lumber to make the parts out of -- something along the lines of vertical grain fir, poplar, clear pine, ...
Given the cost of the wood and the time involved, I would suggest spending about $150 at a big box store and buying a prehung metal door. That's about the amount on money that the wood to do the repair is going to cost, and the prehung can be installed in a matter of 4 to 6 hours -- less if you've done them before.
