Marble Window Stools
Old 01-28-08, 07:43 AM
I live in Florida where interior windows are basically un-trimmed holes in the walls. They are dry-walled with marble sills/stools. I want to trim out the windows and install wood sills. Are the stools fastened with adhesive? How much damage can I expect to do trying to remove them?
Old 01-28-08, 09:37 AM
Received 759 Upvotes on 664 Posts
Welcome to the forums!
I used to live/paint in fla. The better houses I worked on had marble sills. The cheaper ones used tile or wood so you may want to rethink your plan.
If I remember correctly, they were usually installed with thinset or grout. I don't know if you can remove them without any breakage.
Old 01-28-08, 10:09 AM
mango man's Avatar
why not put the wood over the marble ?
They can be removed , getting them out in one peice tke a lot of patience .
