replacing old windows
Old 01-30-08, 05:36 PM
B
Iam replacing old steel framed windows.The stucco kind of rounds off and the window sits behind it. what is the best way to remove these and replace them.
Old 01-30-08, 11:12 PM
YOU HAVE TO CUT THEM OUT WITH A SAWZALL,OR CUT THE STUCCO BACK A COUPLE OF INCHES WITH A GRINDER TO REMOVE THE NAILING FLANGE,THEN YOU CAN INSTALL A WOOD BORDER,AND CAP IT WITH ALUMINUM-----EASIEST WAY IS TO REMOVE THE SASHES AND CUT OUT THE JOINING MEMBERS AND USE A "panned"window,measure to the inside of the remaining steel frame,these windows are made with a flared wider exterior flange that will cover the old window frame.on the inside ,you install u-clips,then cut same color metal trim(panning)to size,clip it to the u-clips,and seal--you can call CRYSTAL WINDOWS IN QUEENS,NEW YORK for those type windows,unless you have a closer distributor
