Replacement Window for French Doors
Old 02-24-08, 10:20 AM
T
Question Replacement Window for French Doors
I am trying to find out if anyone might be able to direct me to the proper place to find replacement window insets for french doors. Our french doors are fine, we just want to replace the window inset. Any suggestions?? Thanks so much.
Old 02-24-08, 11:18 AM
Its a pane
Is this a single pane or double pane door? Either way you can probably find what you need at your local glass shop. Depending upon the size it would need to be a safety glass--either laminated or tempered. Laminated has the nice feature of having a plastic between two layers of glass. It is harder to break through laminated so it is nice to have in doors.
Your local shop can either order an insulated unit if it is double pane glass, cut a piece of laminated for you, or order you a piece of tempered glass.
Jim
