New handle latch too big for my new door
Old 05-12-08, 09:51 AM
Z
Hi,
As I'm getting ready to replace a door in my house, I have run into a small issue. The latch is slightly too big (probably 2mm) for the hole in the door (it is a factory made jointed pine door). Since I already sanded, stained and varnished the door, I am a bit wary of doing anything that might destroy it completely. Does anybody have any suggestion on how to enlarge the latch hole? The handle is a lock-less Weiser 25mm latch.
thank you,
Alexandre
Old 05-12-08, 03:14 PM
You must be in the north provinces, we still don't use metric, well sometimes, down here. An older lockset here Might have been 2", where the current standard is 2 1/8. Since I use holes saws, it would really mess up a door without a guide, which I have made. A piece of plywood(2 actually-depending on the setback) with the proper size holes. I carefully center it on the old holes, clamp it, and use it as a guide to open the new hole. Works just fine. If the old hole was small, the bore for the latch is also likely too small.
