Front door hitting frame, not closing
Old 05-30-08, 07:46 AM
R
My front door hits the frame at the top making it difficult to pull closed. The door is slightly tilted away from the frame at the top. How can I reset the door back to square? There is a glass storm door attached that is also tilting the same way.
Thanks.
Old 05-30-08, 02:44 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Check the top hinge to make sure there is a 3" screw installed. Probably not. If not, remove the #2 down screw, discard it and install a 3" screw in the hole and tighten it well. It should correct your door's sagging issue. Let us know if that helps, or if we need to punt.
