Basement windows w/no screens
Old 06-22-08, 09:09 AM
My house is approx 18 years old. My basement is mostly underground except for the top 2' or so in the back. I have 3 basement windows approx. 24" x 12". They are single pain w/no screens.
It does not appear that they were designed with the intention of installing screens. I'd like to use these windows to provide ventilation to my basement but would need some type of screen if they are to be opened.
Do I have any options besides replacing them?
Thanks
Scott
Old 06-22-08, 09:13 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
What kind of window? Do they tilt in or out, or do they slide?
Metal frame or wood or...??
There are any number of ways to attach screens to either the window itself or to the frame. If you are handy you could make some yourself, but I'd suggest going to a good hardware store or glass shop that makes screens, and talking to one of the folks there. Take pictures with you so they know what you have. They will be able to suggest the best way, and will make your screens or sell you what you need to DIY.
Old 06-22-08, 09:16 AM
They are sliding type w/metal frames.
Wall is poured in place concrete.
Thanks again..
Scott
Old 06-22-08, 09:54 AM
Gunguy45's Avatar
Super Moderator
Ok, so not a big problem, you really will only need a 1/2 screen. Just to cover the opening when you slide the moving glass over. If they are like the ones I have seen in the past, you could make it or have it made, then just drill some holes and screw it to the frame. The screws shouldn't interfere with anything since the moving glass is on the inside, right? Just avoid nicking the glass in the stationary panel. Fancier would be to use some swiveling screen retainers, but you may not have room in a basement window, depends on the width of the frame. Prob no more than $10-12 per window to have 'em made, depends on where you live.
The simple solution would be to use one of those universal screens. They can expand to fit the width of the opening, but may not be the right height. They work better on regular
vertically opening windows.
